VEX Forum
VEX Forum (http://www.vexforum.com/forum.php)
-   General Forum (http://www.vexforum.com/forumdisplay.php?f=2)
-   -   Motor Controller 29 On Fire (http://www.vexforum.com/showthread.php?t=60604)
TRWSHSHLX 11-28-2011 07:22 PM
During the meeting today, my team was wiring the robot and one of the motor controller 29s quickly overheated, started smoking, then eventually caught on fire, melted the plastic case (I thought the fire was going to stop eventually but our coach thought differently and told me to unplug the wire, and as far as right now, he seems to be correct since the fire only grew bigger before I unplugged the wire).
Did this ever occurred to any other team? Or is this an isolated case?
The motor controller 29 is connected to a power expander, along with 3 other motor controller 29s that's connected to other motors. There shouldn't be any issue with the motors / power expander ports since they had been used in competition without failure previously.
After putting a new motor controller 29 on there, everything work fine. There was no overheating, smoke, or fire.
What might cause this incident?
Also, this brings up another question, what action should be taken if a robot started on fire in the duration of a match?
I'll attach the pictures tomorrow.
Rick Tyler 11-28-2011 08:50 PM
Re: Motor Controller 29 On Fire
Quote:
If something like this happened during a match at a tournament that I was running, the match would be stopped and the issue would be dealt with. Safety is far more important than any other consideration.
devinc 11-28-2011 09:28 PM
Did you ever have to do any wiring repairs on it? That's all that I could think may have happened.
fretless_kb 11-28-2011 10:15 PM
Can't say I've heard of it in Vex competitions, but I saw several failed motor controller 29s in the BEST competition. - No fires thankfully but the controller seemed to overheat and fail.
Cheers Kb
RampantFang 11-28-2011 11:24 PM
Yes, last year this happened to our team. Not quite certain about the exact cause, but we were pushing our 393s pretty hard when one of the motor controller 29s started smoking. After we replaced it, though, all was well... gave us quite a scare though.
And just some additional information, it was attached to the power expander and we had filled up all the motor ports on the Cortex while using the maximum legal amount of power (6 269s, 4 393s).
Hope this helps.
TRWSHSHLX 11-28-2011 11:39 PM
I was still in the testing stage of determining where the motors are running the correct direction when the incident happened. So there shouldn't be any power problems.
Also, I noticed the motor with the motor controller 29 that caught on fire "locked Up" when the controller was overheating itself.
murdomeek 11-29-2011 12:52 AM
this happened to one of our motor controllers as well
the motor wasnt working properly and when we touched the motor controller, it was very hot!
luckily it didnt melt, smoke, or catch on fire
when we replaced the motor controller, the motor worked and everything was fine.
at that time, we had a single battery, old pic, crystal/radio,and only 4 motors hooked up
hwilson 11-29-2011 12:54 AM
We had this happen a few months ago with the Cortex H-Bridge instead of the motor controller. A similar situation occurred in which a smaller fire started, however this was stopped before it got out of hand (and the cortex still works fine now except for the 2 wire ports)
We believed it was caused by a large draw of current on the H bridges (which are also present on the motor controllers) as is what seemed to start the fire with the large draw of current from 2 heavy duty motors
jgraber 11-29-2011 08:21 AM
I've seen a number of Cortex H bridge burnt out, particularly by rapid forward/backward changes with BEST Large motor loads.
Sometimes a puff of smoke, but no fires.
Two years ago, there was (reportedly) a firmware problem that allowed "shoot-through" current on the H-bridge in the Cortex.
US consumer electrical plastic compounds are generally required to be "self-extinguishing", so removing the heat source by unplugging the battery, pulling the wires, etc, should put out the fire.
My understanding is that there are thermal breakers in the motors to keep them from over heating, and PTC current limiters supplying a branch of 4-5 H-bridges.
Worst case condition would seem to be two heavily loaded motors on a Y cable to the one H-bridge, with no other motors in use.
I don't understand the description "Lock Up", please use other words, eg:
"motor stops, doesn't respond to commands to move,"
vs "motor keeps spinning, doesn't respond to commands to stop".
Other good reporting practices:
- What is motor application? lifting an arm or mech? drive train?
- What is motor hook up? Y cables? motor port? expander port? battery type?
- What serial number, revisions, other markings (if still readable) on mc#29, motors, power expanders, Cortex/Pic?
- What type of code is driving motors? EasyCv4 Tank4, Custom PID RobotC arm potentiometer feedback?
- What exact (not just "latest") version of EasyC or RobotC is in use?
magicode 11-29-2011 08:48 AM
I'm surprised to hear that. Aside from the firmware problem that you mentioned, I've seen very few controllers in the cortex burn out.
VEX and VEX Robotics are trademarks or service marks of Innovation First International, Inc.
Copyright © 2002-2015. All Rights Reserved. VEX Robotics, Inc. is a subsidiary of Innovation First International, Inc.
All other product names/marks of others are the property of their respective owners.
Patents and/or Patents Pending: innovationfirst.com/patents
