Go Back   VEX Forum > Official VEX Technical Support > UNOFFICIAL Answers - Ask the Community!
UNOFFICIAL Answers - Ask the Community! Community Members can provide UNOFFICIAL answers to the questions from the "locked" forum above.
Reply
Thread Tools
  #1
Old 04-13-2012, 07:45 PM
DiodeTech DiodeTech is offline
Senior Member
VEX # 181
Bumper switch info error
On the vex product page: http://www.vexrobotics.com/products/.../276-2159.html
it states in switch info that the switch is normally open, but states next in the signal behavior:
"When the switch is not being pushed in, the sensor maintains a digital HIGH signal on its sensor port. This High signal is coming from the Microcontroller. When an external force (like a collision or being pressed up against a wall) pushes the switch in, it changes its signal to a digital LOW until the switch is released. An unpressed switch is indistinguishable from an open port."
Are HIGH and LOW switched in this part? My understanding of high and low is that high is powered and low is off. Is this my understanding or a typo?
Thanks
  #2
Old 04-13-2012, 08:01 PM
Senior Member
VEX # 181
Re: Bumper switch info error
Or is it high impedance and low impedance?
  #3
Old 04-13-2012, 08:02 PM
jgraber jgraber is offline
Senior Member
Images: 13
This thread is in the wrong forum, I'll flag it to ask that it be moved to community technical support.
The switch is normally open: true;
The cpu provides a pullup resistor: True;
The digital input value of an empty input port is 1 (due to pullup): true;
The digital input value of an input port with a switch (not pressed) is 1: true;
The digital input value of an input port with a PRESSED switch is 0: true;
No.
The piece you might be missing is that the switch is connected between the input and Ground, so when the switch is closed/pressed, it shorts the input to ground = 0, to override the pullup resistor default power = high = 1.
This is common in electronics, sometimes called "active low", because it is easier for some electronic technologies to short to ground than to provide power.
  #4
Old 04-13-2012, 08:03 PM
MetalJacket325's Avatar
MetalJacket325 MetalJacket325 is offline
Senior Member
VEX # 2068
Images: 3
I'm not sure about high and low but, in easyC a pressed bumper reads 0 and an unpressed one reads 1
  #5
Old 04-13-2012, 08:10 PM
RoboDesigners's Avatar
RoboDesigners RoboDesigners is offline
Senior Member
VEX # void
Images: 1
In ROBOTC, this is reversed...
__________________
  #6
Old 04-13-2012, 08:24 PM
Senior Member
VEX # 2068
Images: 3
Quote:
The reversed way (1=pressed, 0=not) makes more sense, that's one thing in easyC that bugs me
  #7
Old 04-13-2012, 08:43 PM
jpearman's Avatar
jpearman jpearman is offline
Senior Member
VEX # 8888
Images: 2
Yes, it depends if you set the sensor as a "Touch" sensor or a "digital in" sensor. Digital in works the same as EasyC, 0 = pressed. The touch sensor reverses this and 1 = pressed. I find it sort of annoying to be honest but guess it makes sense.
  #8
Old 04-13-2012, 08:44 PM
Senior Member
VEX # 181
Thanks for the quick replies. It appears the confusion lies in the fact it is not solely a basic switch circuit. I think I understand now, but pulling resistors is a little beyond by electrical engineering knowledge. Sorry about the wrong forum, I was debating if it was a question about the website or the switch itself.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
VEX and VEX Robotics are trademarks or service marks of Innovation First International, Inc.
Copyright © 2002-2013. All Rights Reserved. VEX Robotics, Inc. is a subsidiary of Innovation First International, Inc.
All other product names/marks of others are the property of their respective owners.
