| General Forum Open Discussion of the VEX Robotics System that can be answered by anyone. VEX Robotics Engineers will not answer questions posted here; see Official VEX Technical Support below. |
Thread Tools |
#1
VEX Custom machined twoish inch Mecanums
During the summer of 2011 i decided that i would embark on the process of Designing, CAD modeling, and Machining my own mecanum wheels for VEX. I started out with looking to GER for the concept design of the wheels but after that i had to CAD model the wheels in order to make myself able to machine them.I used the two high strength gears and omni wheel rollers to make them (just like GER). I created two Jigs to make them i used one for the Mill and one for the Lathe. i bolt the gear to the Jig in the lathe to take off the teeth and then bolt it into the jig where the gear is mounted at a 45 degree angle, drill down, unbolt, turn one rotation, bolt in, drill down, unbolt and repeat six more times for one half of a wheel. Then you have to change drill bits for the axle hole and do it all over again.
#3
Re: VEX Custom machined twoish inch Mecanums
I really like this mecanum design but I have a few questions.
How are they? I'm not sure because they are gears but what is the approx. diameter with the teeth removed? Are there current VEX wheels with the same or very close diameter? Have you guys used them on a competition robot? What advantages do you see when compared to the regular mecanum wheels that VEX sells? Would you suggest making them if a team did not have access to a lathe? On a scale of 1-10 what was the difficulty of making these? |
#4
Quote:
I would have to check the wheels to be sure(i'll do it tomorrow) but they were about 1.7 inches including omni wheel. There are currently no VEX manufactured mecanum wheels with a diameter close the only ones they have are the 4 inch ones Yes we are the first team to use mecanum wheels in competion because we used them before they came out and continued to use them in competition even through the worlds competition |
#5
Quote:
#6
Quote:
I think that the difficulty would be anywhere from an 8-10 depending on your experience in machining parts i had help from one of our machinist FRC mentors with advise on how to do it and the basic how to get started but it was more that we were working together to figure it out but once we did it wasn't too much work In a nutshell most of the difficulty is getting your setup in the mill right and making the jigs. |
#7
Vex needs to market these
i spoke to your members at worlds these were genius. thank you for have exceptional original ideas. |
#8
Quote:
- Andrew |
#9
Quote:
#10
Quote:
If someone wants to test the tiny ones vs. the large ones in a full design comparison I would be quite awesome. Meaning things like forward backward speed, pushing power forward and backwards. Side to side translastion speed loss. Side to side pushing power. The works. - Andrew |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
