Go Back   VEX Forum > Community > General Forum
General Forum Open Discussion of the VEX Robotics System that can be answered by anyone. VEX Robotics Engineers will not answer questions posted here; see Official VEX Technical Support below.
Reply
Thread Tools
  #1
Old 08-29-2007, 06:51 PM
LogJam LogJam is offline
Junior Member
Just Received Vexplorer - Initial Thoughts...
Today, the UPS man delivered my Vexplorer! (You gotta love the sound of that brown truck. Its distinct sound lets you know your package is almost here.) Although I have not had the opportunity to completely utilize this new set, here are my first thoughts:
The Vexplorer is very well packaged - UPS stated it was 12 lbs, but my postal scale said 8 lbs, maybe the outer brown box made up the difference? All parts are well sealed in separate compartments within the stryofoam tray.
This set is definately aimed at an audience with little robotic experience - which is not a bad thing. Some sections of the main robot (the one with the claw and camera) are already assembled - stating to allow the user to assemble and get going in about an hour. The claw, arm assembly, and both wheel assemblies (3 wheels, 2 motors, gears, axels, and supporting structure) are the pre-assembled portions.
Assembly was not entirely enjoyable. Now, I consider myself only an intermediate robot-builder, so those of you who are experts may have an easier time. In an effort to pre-assemble the robot for you, it appears that some areas of the overall assembly were made unnecessarily more difficult. At certain points; a beam of the arm assembly, a motor, etc were quite simply in the way of building another section. Since the arm assembly was shipped with the arm in a raised position (rather than in a horizontal position as in the instructions), it was difficult to attach the camera to the arm. I had to jump ahead, attach the battery pack, temporarily wire the receiver (microcontroller) module, and use the remote to lower the arm to properly attach the camera. In many instances, the pictures in the instructions were not as clear as they should be (printed too darkly), requiring me to look ahead to find an diagram later to figure out what VexLabs wanted me to do.
The instructions provide 2 options for attaching the antenna: wire tie to the structure (as shown in the instructions) or by using an antenna holder similar to the one in the Vex Starter Kit. However, unless I missed it, there is nothing showing the antenna holder and its use. If you have no prior experience with Vex sets, you may be confused. I knew what this piece was from my Starter Kit days.
Vexplorer comes with the standard Vex wrench and 2 different Allen wrenches - one of which was not needed in this construction. The instructions state that you should use the open-ended wrench to hold the nuts properly when tightening the hex screws. I found this impossible, but rather needed to hold the nut at awkward angles with a small pair of pliers. Perhaps the experts here would have no problem.
I had to sort of rig the battery pack and receiver module, as I did not find them to fit exactly as the instructions stated. The preassembled parts were in the way of later sub-assemblies, as stated above.
The wires from the motors and camera have reversible plugs - so they can be installed in either direction to change the desired motor direction. There is a nice chart stating which wires get plugged into which slot - except for the wire from the camera. It is hinted at on the following page that the camera utilizes the auxiliary port on the receiver is used - but not directly stated. For a newbie as this product is to be targeted, perhaps it should be.
The Vexplorer receiver is about 1/2 to 1/3 the size of the Starter Kit microcontroller, and is not programmable - which makes sense for a kit designed for this type of target audience.
The motors are not compatible with the Starter Kit, using 2-wires. Most other parts are interchangeable with the standard Vex sets. The gears and metal parts appear to be made of the same material as the standard Vex sets, just a different color. The wheels appear to be different from anything Vex released previously, but I have not verified this.
Like the traditional Vex sets, Vexplorer uses a lot of batteries: 6 AA onboard the bot, 4 AA in the camera receiver, and a 9V in the remote. There is a plug on the camera receiver for a power pack (not provided). I am not sure if rechargable AA's can be used or if a battery pack will be later available from VexLabs.
I wish the instruction book included assembly instructions for the portions that came pre-assembled. A newbie may want to disassemble them for another project and want to re-assemble the original robot later. Perhaps VexLabs will release this later. Some may be afraid to disassemble the pre-assembled sections for fear of forgetting how they originally were put together.
I would also have hoped VexLabs would included assembly instructions for more than 1 type of robot. Although there are completed "idea robots" shown at the end, a robot newbie may be discouraged that they only have 1 set of instructions to follow. True, the point is to give the user a little to start with and then let you experiment on your own - but for this targetted audience they may need/want more (?) I am not sure, this is open to a good discussion.
Once assembled and wired, the fun continues! The remote control is very intuitive and the bot more around with good speed. I had to reverse one of my wires, as when I put all the plugs in the same direction, the remote could not be used as I intended - an easy fix. Arm and claw have both strength and dexterity - able to lift a fair amount of weight, yet grasp small objects. The claw is well-designed and well-shaped with soft rubber grips to really hang on to something. I need to further test its complete ability yet.
The camera image quality was better than expected. Its never going to compete with the professionals - but the image is very nice and provides a good picture as expected for this set. Simply connect the camera receiver to the yellow and white RCA ports of your TV (cable provided), make sure the camera and camera receiver are on the same one of four channels, and power everything on! Easy! The image appears on your TV within a few seconds. You do have to make sure you are in a very-well lit room for the best picture. You can connect this to a DVD recorder and record your adventures. The camera's built in microphone is of a fine quality - but sensitive - it does pick up all of the robot motor sounds. This is not a problem, just something to keep in mind. I thought it was cool that the camera is positioned just right so you can see the claw open and close on the TV - which helps you to position the claw as you watch.
The signal from the camera to the camera receiver has good range, as well. I sat in my basement watching the TV and remotely piloted the robot throughout my upstairs with only very minimal reduction of signal in only a few certain areas. I have to test the range further. The camera operates at 2.4 GHz, so you may experience interference from certain cordless phones, wifi, etc. The robot remote operates at 27 MHz.
Vexplorer also comes with the "SolidWorks Student Design Kit" software in DVD format, good for 150 days or until November 30, 2008 - whichever comes first. I have not had an opportunity to try the software yet.
The Vexplorer is a lot of fun and I can't wait to really put it through its paces. I am a little concerned the assembly may turn off some of those who are newer to robot building, but perhaps it was just me. This was definately a worthwhile purchase, and I look forward to using it more.
Another fine product!
Kind Regards,
Mike
P.S. Anyone else get a Vexplorer yet? What are your thoughts? Do you agree or disagree with anything I stated here? I'm interested what others think.
  #2
Old 08-29-2007, 07:02 PM
Technic-R-C's Avatar
Technic-R-C Technic-R-C is offline
Senior Member
VEX # 2500
Images: 13
Re: Just Received Vexplorer - Initial Thoughts...
Thanks for the product review. It answered some of my questions
__________________
Vex Elevation 2009 World Championships - #2500 Ranked 4 Alliance Captain!!!
Vex Elevation at IRE #1 TOURNAMENT CHAMPS
Vex Bridge Battle at IRE ranked #2 Team Polvex
VRC team Polvex #2500 Leader
FRC team Smokey Bears 2358 Leader
“Success is determined by those whom prove the impossible, possible.”
  #3
Old 08-30-2007, 11:04 PM
texasranger's Avatar
texasranger texasranger is offline
Senior Member
Images: 10
Send a message via AIM to texasranger
A quesion about the wheels: do they lock on to the axle?
there was a problem with the starter kit with the instructions. I'm not EXACTLY sure how it happened, but i think vexlabs planned on having locking wheels, wrote the instructions with that in mind, and then decided not to, and forgot to change the instructions to specify that. Locking wheels are good if you don't have many collars (if you only have the starter kit) and want to save (you'd save a quarter of them just by having locking wheels).
__________________
Posted from my iPhone using Safari
RE5PECT
  #4
Old 08-31-2007, 06:21 AM
GGCO's Avatar
GGCO GGCO is offline
Senior Member
Images: 1
This might be a dumb question, but I was wondering if the Vexplorer used the same parts as the Vex Starter Kit? Also will they sell the arm and camera seperatly so I could use them with the starter kit?
  #5
Old 09-05-2007, 12:25 PM
Junior Member
I think I can answer both of these sets of questions:
- The wheels do lock onto the axles and are held in place with the same drive shaft collar as a standard Vex kit.
- The Vexplorer uses MOSTLY the same parts as the Starter Kit. The claw uses some parts obviously different, but the bulk of the parts are the same, except for the color.
Interestingly, some parts of the pre-assembled portions of the Vexplorer are not fastened in a traditional fashion. The Delrin bearings, for example, are not fastened using standard Vex screws and nuts - but rather using some sort of plastic pin that pushes thru the Delrin and spreads slightly on the other side. I do not know if this was meant to be a semi-permanent form of attachment, but if so would then disappointingly limit the number of pieces that could be disassembled.
Any comments from VexLabs?
Kind Regards,
Mike
  #6
Old 09-06-2007, 02:20 PM
PHYSICMAN's Avatar
PHYSICMAN PHYSICMAN is offline
Junior Member
Images: 18
VISIT THIS FOR THAT NOT SO DUMB QUESTION.
http://www.botmag.com/articles/06-07-07_vexplorer.shtml
__________________
"Think, Think, Think,
you will never get
an idea unless you
use your imagination." - ME
  #7
Old 09-07-2007, 12:40 AM
John V-Neun's Avatar
John V-Neun John V-Neun is offline
Images: 17
These bearing pop-rivets are 100% reusable. They can be pushed out and reinstalled with your fingers. Try it!
JV
__________________
John Vielkind-Neun
Director of Product Development
VEX Robotics, Inc.
  #8
Old 09-07-2007, 12:41 PM
Junior Member
Quote:
JV
That is good to know. I was afraid to try it, but now that I know - I shall!
On another point, I also noticed that the manual has changed. In my original review post, I mentioned that the building instructions did not show to use the antenna holder - you would have to know what it was from previous experience. In my manual, it states to use wire ties to attach the antenna to the arm assembly. The new manual that can be downloaded from VexLabs does not show the wire tie option, but rather the antenna holder. A good change!
After playing with the Vexplorer some more now, I find the remote control to be just a bit too large. It's not too large to be uncomfortable, but if an adult finds this large, I can only imagine a child would, as well.
Still - the Vexplorer is a lot of fun!
Cheers,
Mike
  #9
Old 09-19-2007, 07:47 AM
Images: 17
Another Vexplorer Review, for those interested in learning more:
http://blog.trossenrobotics.com/inde...lorer-unboxed/
__________________
John Vielkind-Neun
VEX Robotics, Inc.
  #10
Old 09-23-2007, 10:35 AM
basicxman's Avatar
basicxman basicxman is offline
Senior Member
Images: 5
Send a message via Skype™ to basicxman
No offence to VexLabs but I find the VEXplorer set kind of takes the fun away. I like to build and program by 'bots but the microcontroller isn't programmable and its already nearly assembled. I agree its good for begginers but I say the starter kit is way better.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
