Go Back   VEX Forum > Community > New Product Release Info
New Product Release Info Check here to see the latest products that have been released.
Reply
Thread Tools
  #11
Old 09-17-2008, 05:49 PM
Quazar's Avatar
Quazar Quazar is offline
Senior Member
Images: 13
Re: VEX Gyroscope and Accelerometer Information
Quote:
Originally Posted by Edmund Harfmann View Post
For the accelerometer, will it use one big connector (for 3 sequental port) or will it use 3 connectors so that you could plug it into ports 1, 3 and 8?
I predict they will be separate for two reasons:
  1. IFI already has the single-port connectors in production and there isn't much advantage in a new part if it isn't needed
  2. Having them separate allows you to use the minimum number of ports if you don't need all three axes for a given design.
Cheers,
- Dean
  #12
Old 09-17-2008, 06:04 PM
MarkO's Avatar
MarkO MarkO is offline
Senior Member
Location: Albany, Oregon, USA, North Western Hemisphere, Planet Tera
Images: 10
Cheers,
- Dean
Good Call on both points.
I guess that there are times when only One or Two Axis would be needed.
  #13
Old 09-17-2008, 09:37 PM
vexbot's Avatar
vexbot vexbot is offline
Senior Member
Images: 3
Cheers,
- Dean
That's what I would have said too.
Depending on what you are using the Accelerometer for you might only need to use 1 axis. Using separate cables for each axis allows more flexibility for us users to chose which axis we want to use and which analog port we want to put it on. Plus, you wouldn't need a special cable.
__________________
Allen
A VEX Robotics Hobbyist
2 trips to World Championships in Dallas - Elevation and Clean Sweep
Hopefully, a third trip for Round Up!
  #14
Old 09-18-2008, 06:57 AM
Edmund Harfmann Edmund Harfmann is offline
Junior Member
Lightbulb Re: VEX Gyroscope and Accelerometer Information
That makes way too much sense. I'm playing around with updating the MSRS services to include some of the new 'toys' and trying to figure out how it should be implemented. Sadly, that complicates the interface somewhat.
Oh well. Just have to think about it some more.
Thanks (I think :>) for giving me a different viewpoint.
Ed
  #15
Old 09-18-2008, 09:01 AM
Quazar's Avatar
Senior Member
Images: 13
Well, if it is three connectors, then I'd just model it as instances of single-axis accelerometers. The fact that the three wires all go to the same sensor unit is not really important - from a software perspective, they could just as easily go to three separate single-axis units.
Cheers,
- Dean
  #16
Old 09-18-2008, 05:49 PM
Junior Member
Smile Re: VEX Gyroscope and Accelerometer Information
Sounds like a good approach. Originally I was thinking of how to match each axis but as you say it doesn't matter at my level. That is for a higher level of abstraction. It will mean that each accelerometer could be 'miss programmed' with the gain different, but I'll leave that as an exercise for the user to realize....
  #17
Old 03-31-2009, 06:42 PM
vamfun vamfun is offline
Member
Images: 6
Send a message via AIM to vamfun
Quote:
Originally Posted by Bob Mimlitch View Post
Then we added three rail-to-rail op-amps on the output to bring the voltage back to 0.05V - 4.95V.
So do we use the 0 to 5v or .05 to 4.95v for scaling?
Unless told otherwise, I'll assume its 0 to 5v.
So the new Vex output scaling for the 1.5g range will be :
800*5/3.3= 1212 mv/g
The zero g bias 1.65v*5/3.3 = 2.5v
I guess the next question is how have you affected the bias, scale and noise errors with your amplifiers?
What is the signal conditioning of your board? Do you have an added 1 pole filter or are you just using the 1k,.1uf filters on the freescale chip. It would help if you posted a schemetic so we can know how to change the pole cutoff with additional capacitors.
Perhaps you can add some of this info to your product website since the freescale stuff no longer applies directly.
__________________
Chris
Prof Mentor RoboDox Team 599 , Granada Hills, Ca.
Retired Lockheed Avionic Systems and Flight Control Engineer
  #18
Old 07-28-2009, 04:40 PM
MarkO's Avatar
Senior Member
Images: 10
Quote:
Originally Posted by Brandon Martus View Post
VEX Analog Yaw Rate Gyroscope V1.0
The VEX Gyro measures turn rate, so it can be used to calculate how much a robot has turned. This allows for very precise turning (example - you can program the robot to turn exactly 90 degrees to the left). Using the VEX Gyro a programmer can also adjust for any drivetrain drift; this turning correction can be used to ensure a robot drives straight. The Gyro could also be used to create a self-balancing robot and to measure robot tilt (such as detecting if the robot is on the ramp or tipped over).
  • ±300 degrees per second full scale
  • 0-5V analog output
  • Uses the LISY300AL chip
  • LED indicated power and proper connection
  • Mounts directly to VEX
  • Price: $49. Availability: November 2008
LISY300AL Chip Information:
The LISY300AL is a low-power single-axis yaw rate sensor. It includes a sensing element and an IC interface able to provide the measured angular rate to the external world through an analog output voltage. The sensing element, capable of detecting the yaw rate, is manufactured using a dedicated micromachining process developed by ST to produce inertial sensors and actuators on silicon wafers. The IC interface is manufactured using a CMOS process that allows a high level of integration to design a dedicated circuit which is trimmed to better match the sensing element characteristics. The LISY300AL has a full scale of ±300 °/s and is capable of measuring rates with a -3 dB bandwidth up to 88 Hz.
<<< SNIP >>>
Is there any Status on this Product???
  #19
Old 07-28-2009, 06:03 PM
Rick TYler Rick TYler is offline
Senior Member
VEX # 10(n)
Images: 74
Quote:
Mark, it's been for sale for quite a while (we have one): http://www.vexrobotics.com/vex-robot...erometer.shtml
__________________
Robotics Education and Competition Foundation (RECF)
Mentor, Venturing Crew 2036, the Exothermic Robotics Club: VRC 10A, 10B, 10C, 10D, 10E, 10Q, 10V, 10X, 10Z, and 575
Other teams in the Exothermic Robotics family: VRC 1899
  #20
Old 07-28-2009, 06:12 PM
MarkO's Avatar
Senior Member
Images: 10
Quote:
The accelerometer, yes, I have now too.. I was inquiring about the Gyroscope V1.0. They are different things... MORE TOYS!!! I mean tools...
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
