| Technical Discussion Open Technical Discussion of the VEX Robotics System. |
Thread Tools |
#1
Partner joystick communications protocol
One of the things I really enjoy is figuring out how things work. A question was asked about the partner joystick communications and so (although I'm sure JVN will give the official answer) here is what I have found after an hour or so of poking around.
The partner joystick connector is a 4 pin RJ-9 (or is it RJ-22, not sure) and uses a 4P4C telephone handset cable to connect to the partner joystick. Connector pinout Pin1 GND Pin2 Tx Data from the joystick Pin3 Rx Data to the joystick Pin4 GND The connection uses RS232 communication at normal RS232 levels rather than the TTL levels used on the programming port. Communication is 8 bit No Parity (I think) 1 stop bit at 115200 baud. The Master joystick sends a message to the partner joystick roughly twice per second, the message is 4 bytes (shown below in Hex) and seems to be used to keep communication alive. AA 55 3B 01 (This is inconsistent with all other VEX messages, should be 1 more byte if it followed the normal format ) The partner joystick responds with a message similar to the following (again in hex) at a much more frequent rate (to lazy to time it). AA 55 39 0A 7F 7F 7F 7F 00 00 65 7F 7F A1 the breakdown of this is as follows AA 55 39 - header, nearly all VEX messages start with AA 55 0A - data length, including checksum 7F 7F 7F 7F - the values for the 4 analog joysticks 00 00 - the buttons as bitmapped data. ie. one button per bit 65 7F 7F - accelerometer data A1 - checksum, the sum of all data bytes and the checksum byte will be 00 (mask sum with 0xFF ) I will leave it to others to add more detail on switch bit positions, I did decode this for one of the other communication protocols but to be honest I'm too lazy to type it out here. I had the joystick hooked up to a PC through a USB serial adapter, it would be very simple to create a partner joystick simulation if needed. This is obviously unofficial information so use at your own risk ![]() Enjoy Last edited by jpearman; 01-23-2012 at 05:00 PM. |
#2
Re: Partner joystick communications protocol
Im thinking that the data that the Master sends out is for the lights on the partner stick. One byte per light and then the color within the byte.
Edit: Perhaps the normal start byte and the light value and then a checksum. |
#3
Perhaps, I did not monitor an actual exchange between two joysticks, I only have one. I posted this for the students at KTOR to have something to get them going with their custom partner controller. If I have any time in the next couple of days I will throw together a demo application that can simulate the partner joystick.
#4
Thanks Jpearman. It's a great place for us to start from as you said. Right before worlds we'll post our control box if all goes according to plan (ie we can actually figure out how to get it to work).
#5
Quote:
#6
Quote:
#7
We are actually using a phone jack at the moment to achieve the same principle and JVN while we are trying to figure this we would never turn down additional help/information.
#8
Quote:
http://www.vexforum.com/showthread.php?t=24 http://www.vexforum.com/showthread.p...light=protocol There are many of us who would like access to schematics and communication protocols, not for any particular reason but just to educate ourselves. I have looked into many things, both HID and CDC USB protocols used for connection of the cortex to a PC (I have OSX drivers for both), certain aspects of downloading and uploading firmware, the whole ROBOTC communications protocol, internal mapping of IO ports on the STM32 processor, lots of stuff, nothing used for destructive purposes and most of this I keep to myself unless asked about it. Next on the list I guess will be the new I2C interface, what's the clock frequency, how does the address auto-negotiate work as I'm used to static addresses. One day perhaps I'll take a crack at the WiFi protocol, although that will take a little more effort and I'm not that interested. So I hope you will surprise me John and let out a few secrets ![]() |
#9
I was just joking with you.
We will release as much as we can. I'm on the road right now but when I get back to the office I'll discuss in more detail with my team. As you know there are reasons to keep some things proprietary, and reasons to make things public. We try to find the balance between these two... -John |
#10
I know, but it's always an opportunity to jump on the soapbox.
Quote:
Quote:
In the mean time.... Here is a silly little app I threw together this evening that simulates a partner joystick on a PC or Mac. Not very polished, just a bunch of sliders and buttons, but I have no real use for it so don't plan to develop it any further. You can use the prolific serial adapter or any other serial port available (needs to be there before launching the app under windows). Obviously, a custom 4P4C to DB9 cable needs to be made, use the pinout from the first post in this thread. OSX version available for download here. Win32 version available for download here. Enjoy |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
