#12
Re: Field disabling our robot during a match?
First you has said
Quote:
Quote:
This type of problem is very hard to solve unless you can find something wrong with the robot. Lots of theories will be suggested, bad WiFi, motors overheating, low batteries etc. but as the exact conditions of the tournament cannot be recreated you may never know what happened. Test the robot on Tuesday with as close to yesterday's conditions as possible, use the same controller, the same VEXnet keys, same backup battery and see if you can reproduce the problem. |
#13
Quote:
Could it be that our brain and controller weren't on the right master code? or something like that? Would that cause a problem if our controllers and brain had a different master code then the other robots? |
#14
Quote:
If the cortex and joystick were on different and incompatible master firmware and could not communicate with each other then you would have (hopefully) noticed that between matches. EasyC is pretty good about checking firmware versions before you can download user code unless you have disabled that feature. |
#15
Was there any wild driving going on? Once our more energetic driver rammed the tower while trying to get a barrel in the corner goal and our alliance's robots cut out, causing a match restart.
#16
No there wasn't
#17
Similar Problems happened to us in new Hampshire in November, we were the team to beat and we got eliminated quarterfinals due to the problems we found out the cortex we received from our local collage team as a gift was a beta version one (the top was flat, the vexnet key was not raised) we invested in a new control system to assure this would never happen again, i know the bundle is pricey but if its costing you wins at competition its worth it. i saw the video of your robot and I'd say its worth buying a new control system your robot looks really good.
#18
Quote:
"Flat-top" does NOT mean beta. Most NC-1 Cortex units are fine. The NC-2 and NC-3 Cortex units are the same inside the case. VEX said they released the pop-top to improve range. |
#19
i have experience this exact issue at all of our competitions this year. i have switched out our cortex, our joysticks, our vexnet keys, and just about everything else (even rewritten our entire code). this issue is persistent and is something i have NOT been able to duplicate with the switch simulator.
#20
Quote:
If it is a NC-1 Cortex could it be possible that this is our problem? And if it is would there be anything vex would do about it? I will check tomorrow when I get to school. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
