Go Back   VEX Forum > Official VEX Technical Support > UNOFFICIAL Answers - Ask the Community!
UNOFFICIAL Answers - Ask the Community! Community Members can provide UNOFFICIAL answers to the questions from the "locked" forum above.
Reply
Thread Tools
  #1
Old 02-24-2012, 09:03 PM
Jacob Wall Jacob Wall is offline
Junior Member
VEX # 4770
Controlling/synchronizing a lift system in ROBOTC?
So, my team and I have a bit of an issue. We've been trying to quickly bring our robot together for a gateway competition tomorrow.
You can see our mostly-assembled robot in the picture below (note that the picture is slightly outdated, and we have moved some motors around and removed the two pieces of metal that run between the lift system, but it should give a general idea):
The issue we're having is with the four-bar linkage designed to lift the conveyor-belt intake system (that would pick up, hold, and drop game objects).
We have a motor powering each of the four bars, where they are connected to the rest of the chassis; the two motors towards the front of the robot are both high power motors, while the two motors towards the back of the robot are regular motors. We also have a potentiometer to monitor each of the two front motors, and an encoder for each of the two back motors (and we don't have the time or space to change this arrangement).
Unfortunately, sometimes the bars run out of sync, which causes some big issues with our conveyor-belt intake system. So, our goal was to use the two encoders and two potentiometers to attempt to synchronize the four motors (but not necessarily at the same speed, just at an appropriate speed). How could this be done? And if we were to use PID, how should that be configured, what should be the input and where should the output be applied?
  #2
Old 02-24-2012, 09:30 PM
Disciple855's Avatar
Disciple855 Disciple855 is offline
Senior Member
VEX # CSM
Images: 1
Re: Controlling/synchronizing a lift system in ROBOTC?
I would gear (or chain) the connection points on each side together so it’s physically impossible for the bars to run out of sync. As well as maybe Y-cable motors together so that they (theoretically) run in tandem.
I’m a builder not a programmer, so my solutions are usually physical, but I’m sure someone else here on the forums can give you advice on the software side of things. Hope you guys do well tomorrow!
__________________
Even now,” declares the Lord,
“Return to me with all your heart,
with fasting and weeping and mourning.”
Rend your heart and not your garments.
Return to the Lord your God,
for he is gracious and compassionate,
slow to anger and abounding in love,
and he relents from sending calamity.
Joel 2:12-13
  #3
Old 02-24-2012, 09:56 PM
PaperTowels9876's Avatar
PaperTowels9876 PaperTowels9876 is offline
Senior Member
VEX # 1200E
If possible, I would connect an axle all the way accross the two sides of the lift to keep them in sync.
__________________
1200E New Divide
Waukesha, WI
Tournament Finalists
Rolling Meadows, IL
Ranked 2nd after Qualification Matches
Neenah, WI St. Mary Central
7-1 after Qualification Matches
Tournament Finalists (lost 2-1)
Innovate Award
Appleton, WI Xavier Tournament
Tournament Champions (64 Team Tournament)
Numerous other Judged nominations
May Your Axles Remain Ever Straight
  #4
Old 02-24-2012, 10:16 PM
Yoder's Avatar
Yoder Yoder is offline
Senior Member
VEX # 1064P
Send a message via Skype™ to Yoder
I know that one of my teammates managed to do this in easyC using potentiometers.
What he did was got the potentiometers on both sides as close as possible, then if they went out of a certain tolerance range, one of the sides would slow down to sync up. I'll see if I can get him to try and answer more in depth tomorrow.
  #5
Old 02-24-2012, 10:20 PM
Senior Member
VEX # CSM
Images: 1
Smile Re: Controlling/synchronizing a lift system in ROBOTC?
Perhaps you guys shouldn't have removed the linkage between each arm? Oh, and I forgot to say this, but I really like the design. Reminds me of Green egg's elevation robot.
__________________
Joel 2:12-13
  #6
Old 02-24-2012, 11:46 PM
Yoder's Avatar
Senior Member
VEX # 1064P
It might not be possible to sync it up with a bar because of the gear ratio. I know that my team could have put a bar connecting the two lifts, but it would have just ended up being bent in half. 1:15 too strong
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
VEX and VEX Robotics are trademarks or service marks of Innovation First International, Inc.
Copyright © 2002-2013. All Rights Reserved. VEX Robotics, Inc. is a subsidiary of Innovation First International, Inc.
All other product names/marks of others are the property of their respective owners.
