Go Back   VEX Forum > Community > General Forum
General Forum Open Discussion of the VEX Robotics System that can be answered by anyone. VEX Robotics Engineers will not answer questions posted here; see Official VEX Technical Support below.
Reply
Thread Tools
  #11
Old 05-10-2012, 11:18 PM
Previlant Previlant is offline
Junior Member
VEX # AURA
Send a message via Skype™ to Previlant
Re: Shifting X-Drive
Also if anyone's interested, if you make the x drive past 45 degrees you would get more speed in one direction and more torque in the other direction, essentially making it like a shifting drive train without actually having shifting mechanisms.
http://www.youtube.com/watch?v=QLMWJQC71LA&feature=plcp
__________________
VRCC World Championships - 2nd after Qualification, and Judges Award
  #12
Old 05-11-2012, 12:54 AM
dontworryaboutit's Avatar
dontworryaboutit dontworryaboutit is offline
Senior Member
VEX # 254D
Images: 1
Indeed a cool way to make an effective CVT (continuously variable transmission). But, I'm a little wary of that design because of the pivot point. Can it support the full weight of the robot?
Other than that though, very nice use of the speed advantage of an X-holonomic drive.
__________________
254D = 254Doesn't work at competition
254D = redefining "18 inches" since 2009
First make it work, then make it work well.
  #13
Old 05-11-2012, 01:07 AM
bobsalive bobsalive is offline
Senior Member
VEX # AURA
Images: 4
Quote:
We've got most of an arm/lift on that base right now, and it seems okay, although we haven't made it pick up a gazillion stacks yet. With our testing so far it seems that it should work, although that might change.
On a slightly unrelated side note, 254 borrowed two 60T gears from us at Worlds and we never got them back. (it's okay!)
__________________
Andrew - andrew.chen@aura.org.nz
  #14
Old 05-11-2012, 02:35 AM
vdsa vdsa is offline
Senior Member
VEX # AURA
where's the continuous part?
__________________
Toss Up Game Manual || (Still supporting Lynfield College Robotics - 2915, wherever possible)
  #15
Old 05-11-2012, 03:04 AM
Vex Mundi's Avatar
Vex Mundi Vex Mundi is online now
Senior Member
VEX # AURA
Images: 1
Quote:
If you use a continuous actuator instead of the pneumatic cylinder then you can get the full range of ratios 1 - ∞, not just 1 and 1.4.
We were hoping to be the first team on the forums to point that out, in our writeup of the offset X-drive Previn linked to, but I guess the cat is out of the bag now .
__________________
-Oliver | oliver.wilson@aura.org.nz || Aura Home | Our Photos | Our Videos
  #16
Old 05-11-2012, 05:39 AM
mr. giggums mr. giggums is offline
Member
VEX # 355C
How would you calculate speed and torque if the offset is x degrees apart? I tried to figure this out but I don't know enough about vectors.
  #17
Old 05-11-2012, 06:26 AM
Vex Mundi's Avatar
Senior Member
VEX # AURA
Images: 1
Quote:
I have a draft document on this that I'll try to upload tonight. I'll see if I can get our webmaster (bobsalive) to add it as a page on our website tomorrow.
__________________
  #18
Old 05-11-2012, 09:30 AM
Senior Member
VEX # 254D
Images: 1
If the offset is X degrees from the wheel being pointed straight ahead, the force component straight ahead is given by cos(X) times the force when X = 0. The maximum speed is given by 1/cos(X) = sec(X) times the maximum speed when X = 0. You can verify this result by multiplying the speed by the force:
cos(X) * 1/cos(X) = 1
which says that you are not losing any energy as you rotate the wheels. You are losing a lot of energy to friction as X --> 90 degrees because the rollers are turning very fast.
__________________
  #19
Old 05-11-2012, 11:59 AM
Vex Mundi's Avatar
Senior Member
VEX # AURA
Images: 1
Yes, dontworryaboutit is right (as usual). Here is an in depth explanation if you are interested: https://docs.google.com/open?id=0B_I...0Q2aDBXeXlKb1U
__________________
  #20
Old 05-11-2012, 12:11 PM
JoeG JoeG is offline
Member
VEX # none
Images: 1
Send a message via AIM to JoeG
The math checks out. An N-motor, Y-ratio "X" drive will move faster than an N-motor, Y-ratio tank drive. However, this is a little bit misleading. For a single speed system, you loose signifigant amounts of torque in the "X" drive. Therefore, the N-motor tank drive can be safely geared faster than the N-motor "X" drive, cancelling out the difference if we're talking about two separate robots.
Cool shifting concept though! Reminds me of this. I wonder if a similar linkage system could be applied to reduce the number of cylinders/air consumption required.
__________________
http://wordsaboutrobots.blogspot.com/, the place where I make words about making robots.
VRC 2620A, 2008-2010. No team, for now at least...
FRC 1687, 2007-2010, 2012-???
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
VEX and VEX Robotics are trademarks or service marks of Innovation First International, Inc.
Copyright © 2002-2013. All Rights Reserved. VEX Robotics, Inc. is a subsidiary of Innovation First International, Inc.
All other product names/marks of others are the property of their respective owners.
