1 cortex, switching between EasyC and PROS
Is it a problem to compile and download a program to the cortex from PROS, and then later use EasyC to compile and download a program to the same cortex?
Is there any special formatting that needs to be done to the cortex in between using one program or the other? Or is the process seamless switching between the two?
No problem at all.
Perfect. Thanks both of you. :slight_smile:
