1 motor running at 40x speed of other 3?
I’m using vex code iQ blocks (any chance you need beta testers for IQ text?).
My current bot is a testbed for a stair-climbing bot. It’s the first one I’ve used 4 motors for. I noticed right away that one of the motors was running a lot faster than the other 3. I abandoned the drive train in blocks so I could set velocity independently. Using 1% velocity on that motor, the others run about even with it if they are set to 40%. There doesn’t seem to be a friction issue with the others.
I ordered a new motor, and if I have to, I’ll use the super fast one just for a radar (sonar really) mount.
But is there any way to check the motor, or maybe reset it? All 4 motors updated today to latest firmware (but same result as before).
The control panel on the IQ brain will tell you how fast the motors are running, have you looked at that?
Hadn’t looked at that.
When I do that, 3 motors show about 95 RPMs. The problem motor shows 0 everywhere (but it IS spinning).
broken encoder.
replace the motor.
Thanks, I’ll send it in for a replacement.
