I’ve been using autodesk (Inventor pro 2016) for awhile now and i recently started to build a complete robot. I have the drive done and I started on the lift towers but the “problem” is that I’m wanting to use the 1X3 c-channels for the towers but they don’t have i mates on them and i REALLY don’t want to have to constrain everything when i use it so I’m wondering if anyone would happen to have a 1X3 c-channel part file with i mates that i could use.
Thanks in advance
I think this will work for you. Let me know.
C-Channel 1x3x1x35 Aluminum.zip (1.54 MB)
Nope. For some reason my build version won’t let me open it; not sure why…
Did you use Inventor 2017 to edit it? I know with 2016 it will give me a warning when I try to save something saying that previous versions won’t be able to open the file…
Try this one.
Aluminum C-Channel 1x3x1x35.zip (2.25 MB)
Yes, I used 2017. That would be it. Hopefully Eric Wang’s works for you. Good luck!
Yup, that worked. Thank you for taking the time to do this
Thanks
