So reading over the skills manual I came across
Does this mean that there can only be one mobile goal in only one 20 point zone or does it mean that there can be a mobile goal in both 20 point zones.
There can be 1 mobile goal in each alliances zone, if there are more then one in an alliances zone the one with the highest amount of cones counts for 20 pts while the other doesnt count for anything.
Ok thanks
Actually what they told me was that the one with the highest stack stays in the 20 point zone and the other will count in the 10 point zone
That’s only if you put multiple mobile goal into the same 20 point zone
To clarify further, if there are multiple mobile goals in the same 20 point zone, the one with the most cones counts in the 20 point zone, and any others count in the highest other zone they are touching.
(For example, if the one with fewer cones is touching the 10 point zone, it counts for the 10 point zone, while if the one with fewer cones is touching only the 20 point zone, it counts as if it were out in the middle of the field.)
This comes from this Q&A answer.
Yes, there can be a mobile goal in both 20 point zones, according to this Q&A thread (emphasis mine):
