2 Motors 1 Button
I am trying to figure out a way to have two motors run off of one motor using V5 Blocks. Any suggestions?
You can code 1 button to control 2 motors whether individually or with motor group
Just tried this and downloaded it to my robot. It still doesn’t work.
To get two things working at the press of a button is to do when driver control, if controller1 L1, pressed? then spin motor 1 and 2 forward or backwards else stop motor1 and 2Capture
you can customize the code so it works with your robot
