This is a question about programming the 2 wire ports on the cortex controller (1 & 10).
When a 2-wire motor is plugged into these, they only work with a negative power value, and any power value (-1 → -127) is the same. this is the same for both port 1 and 10. Also, with the same value (-127) port 1 and 10 are reverse of each other (CW and CCW). The pragma config generated for robotc for the 2 ports are:
Sorry I really haven’t searched the forum enough yet but it’s really late and I gotta wake up early tomorrow so if you guys can point me to a document about programming the 2-wire ports that would be great. Thanks so much,
It’s not a software problem since the other one I have runs the code fine. I poked an oscilloscope in there to see what happens. That was the first time I see the signal running the motors by the way. It was very interesting but in the end didn’t yield much result. I decided to put that off for now since everything else works perfectly.
