2-Wire Terminal Connectors
I have several motors and motor controllers that have broken posts on the terminal connector. I would like to replace the connectors. Does VEX have these or are there other suppliers I could get these from?
Hello Domhall,
Thanks for taking the time to contact us.
Unfortunately we do not sell the motor/sensor connector separately; however, you should be able to purchase regular extension cables, harvest the connector and then solder the connector into the damaged motor/sensor:
[http://www.vexrobotics.com/products/accessories/logic/3-wire-cables.html
-Eli](http://www.vexrobotics.com/products/accessories/logic/3-wire-cables.html)
