The rule of the game is simple. I post an image, and you try your best to guess my robot. I will post one picture per day, all the way until worlds. You won’t see much in the first picture, but more and more will be revealed as the week progresses.
I see a blue buckyball outside the field. Clearly this robot has the ability to pick up scoring objects that aren’t even in the field and bring them into play.
Black avant garde art made in paint superimposed on a picture of the corner of a Vex Toss Up Field. The appearance of blue twice and no red may have hidden symbolism but I cannot tell.
I see an intake roller flap on the ground. That must mean this robot has the ability to score the medium sized intake roller flaps in the goal.
I also see cut zip ties. This robot must be able to cut the zip ties, on opponent robots. Or the lift is zip tied down at the beginning of the match, and when it cuts it’s own zip ties, the lift elastically jumps up.
Okay, so your robot will be able to drive, has motors, and a battery. It also has a limit switch, which might mean that the lift can go down to the bottom.
Will you have fancy sideplates? Because if not I can see a zip tie cutting, screw loosening robot being a risk.
Or for a hang.
I like the flag spinner idea, just blow it with the air.
