Intake:
(Each side) 1 269.
4-sided intake roller style.
(held up to 7)
[ATTACH]5155[/ATTACH]
Hal-E II.1 (90% aluminum)
Drive:
(Each Side) 1 396, 3 269…
6-Wheel drive with a 5:3-5:3 ( 2.56:1 ) gear & sprocket ratio with 2.75" wheels. Center wheel a traction wheel and outer wheels the double omni wheels.
Needs a back-view picture to show how the towers are held together, just by the cortex?
Looks like very high CG.
Complicated gear trains, with cantilevered drive sprockets(?!),
lots of fianl torque passing through axles.
I like the pics of your robot. I think it will do pretty well in competitions. But I agree with jgraber with having a pic of the back of your robot so we can see where the cortex will be. Pretty good robot if I have to admitt
By the looks of it, I don’t think it would be hard to pick up objects, but that’s just me. I still agree with mcops, is the life fast. Otherwise, nice bot.
The lift is quite fast. its a 1:8.3 soo it is not much slower than a 1:7 or a 12 tooth to a 84 tooth. it is not hard to pick up balls, but maybe thats just me :).
Upon checking the pictures more carefully, there is clearly an outboard bearing on the main drive sprocket shaft. My mistake, I don’t know how I could have missed it.
The end of a 1x5 back C channel can be seen in one picture also.
I find that crossed C channels in Vex have a lot of wiggle room, due to slop, due to size of vex metal holes vs the #8 screws. Using Shoulder bolts can help this some what.
Good luck in competition.
We have been paired up with a team that has a similar robot, and they preformed great! The one bonus feature I see that this design has is the scoring of 5+ objects in less than 1 second.
I really like your intake design.
Just curious, do you have any videos of your robot practicing, or robot skills?
