Anyone else’s brain not functioning correctly? The new brain randomly locks up, doesn’t update firmware, disconnects motor correctly, and uses up battery very quickly. Is there any way to fix this or atleast when a firmware update will arrive? This new brain was supposed to be better
That doesn’t sound like normal operation, can you provide more details ?
How quickly ? Under what conditions ?
I suspect there may be a hardware fault, I’ve run brains during development for many hours and never seen an issue such as this.
can you explain more ? Typically motor disconnects are caused by physical things such as intermittent cables and/or dirty connectors.
