For my team’s latest robot, we are using a 3-wire expander in order to use tracking wheels and line sensors. In PROS, as far as I can tell, the expander is not officially supported.
I found this api on github and based on the comments and my reading of the changelog it seems like it should work. However, looking at the files to commit, I noticed a lot of them belong to a directory called ‘devices’ within ‘src’. ie: src/devices/vdml_adi.c.
In my PROS projects, the src folder only contains main.cpp. Am I supposed to create new directories or am I missing something?
It is supported, at least in the C API. ADI devices, or at least some of them, support passing a SmartPort parameter, where 0 is the built in ADI ports and 1-21 are smart ports.
In the latest PROS kernels (since 3.3.0 I believe?) all ADI devices have two constructors in the C++ API, one that takes one port as an argument and which references the built in ADI, ex:
As well as one that takes a tuple as an argument, with one value being the smart port of the ADI expander, and the other being the ADI port on the expander, ex.
This is documented in the official PROS C++ ADI API, which can be found here: https://pros.cs.purdue.edu/v5/api/cpp/adi.html @dashwsd and @DrewWHOOP I suggest that you read through through the official docs first in the future when you have any questions about what the PROS API does or does not support.
