4.10 RobotC Graphical Sample Program "Avoid Obstacles" problems
Hello,
I wanted to move on from RC control robots to Auto Pgms, and I’m off to a bad start. Downloaded new RobotC 4.10 Brain is also updated from Vex update and motors and sensors and so forth to 1.10. And the firmware from robot c downloaded as well. I have redone everything a few times as well.
I took the claw assemble off so its set up for sensors right now using ping sensor port 7 and motors 1 and 6.
I went into to motor and sensor setup removed the motors for arm and gripper and made sure that port 7 is the distance sensor.
When robot runs it detects wall stops 1 sec latter goes into reverse but never stops after the second and never does the turn. Then while hooked up it gives you a error. see picture below.
thank you in advance if some one could try this out and see if its robotc issue or my robot, or me.
The message indicates that either:
  1. Something is still in the motors and sensor setup - that refers to a motor that is NOT connected OR…
  2. Your code has left-over references to the motors that you removed related to the arm and claw.
When the code hits a non-existent target object - it will give the message that you attached.
By the way, I only see the screen-capture of the message, and not your code. Do you want to attach the code as well?
Steve just uploaded picture of code and I do press apply removing the clawmotors and so forth.
