Hello! So I have a question about 4 motor bases and 2 motor bases, specifically for a trey bot.
Today when my team was testing we noticed that after in-taking 5 cubes (which we can intake up to 10), our base started moving very slow, and at 7 cubes, completely stopped moving. Our mentor suggested that we use a 4 motor base. But we use 2 motors on our arms, 1 on our tilt mech, 2 for the base, and 2 for the intakes, We already plan to use one motor on the arms, but we were wondering the pros and cons of making a 4 motor base.
We don’t have to take much apart but we only have 2.5 hours to fix it. We were wondering how difficult it has been for teams and how effective it really is.
yeah we have the exact same problem too, so we are using one motor on our arms and using the second arm motor plus our spare motor to get more power on our base.
There really are no cons. Most teams are already doing this. Just make sure your arm gear ratio is strong enough not to overheat the motor and you’re fine
Fastest solution is to put the 100rpm torque inserts (red) on your drive motors. You theoretically get about the same power as 4 200rpm’s at the cost of speed. Not the prettiest solution but it should work as a last resort.
