First time posting on this forum, but I have read a lot of forum posts about PID. Check below for my problem. Hi, so, I have set my constants and done everything that a Youtube Tutorial from Conrad did. Here’s my code.
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
#include "vex.h"
using namespace vex;
competition Competition;
// Define
// Catapult PID constants
double kP_catapult = 0.0;
double kI_catapult = 0.0;
double kD_catapult = 0.0;
// Drivetrain PD Constants
double kP = 0.0005;
double kD = 0.0;
double turnkP = 0.0;
double turnkD = 0.0;
int desiredValue = 200;
int desiredTurnValue = 0;
// Variables for the Catapult PID Control
double error_catapult;
double derivative_catapult;
double previous_error_catapult = 0;
double targetPosition_catapult = 0.0; // Desired catapult angle
// Variables for the drivetrain PID control
int error; // SensorValue - DesiredValue : Position
int prevError = 0; // Position 20 milliseconds ago
int derivative; // error - prevError : Speed
int turnError; // SensorValue - DesiredValue : Position
int turnPrevError = 0; // Position 20 milliseconds ago
int turnDerivative; // error - prevError : Speed
bool resetDriveSensors = false;
bool enableDrivePID = true;
// Catapult PID FUNCTION
void catapultPID() {
// Calculate the error between the target position and the current position
error_catapult = targetPosition_catapult - Catapult.position(degrees);
// Calculate the derivative
derivative_catapult = error_catapult - previous_error_catapult;
// Calculate motor power
double motorPower_catapult = kP_catapult * error_catapult + kD_catapult * derivative_catapult;
// Set the motor power
Catapult.spin(forward, motorPower_catapult, voltageUnits::volt);
// Update the previous error
previous_error_catapult = error_catapult;
// Check if the catapult is within an acceptable range
if (abs(error_catapult) < 5) { // Assuming 5 is the acceptable range
vex::task::sleep(500); // Hold for 0.5 seconds
vex::task::sleep(20); // Sleep for 20 milliseconds
// Drivetrain PD function
// Drivetrain PID function
int drivePID() {
while(enableDrivePID) {
if (resetDriveSensors) {
FrontLeft.setPosition(0, degrees);
FrontRight.setPosition(0, degrees);
BackLeft.setPosition(0, degrees);
BackRight.setPosition(0, degrees);
// Get the position of both sides of the drivetrain
int leftPosition = (FrontLeft.position(degrees) + BackLeft.position(degrees)) / 2;
int rightPosition = (FrontRight.position(degrees) + BackRight.position(degrees)) / 2;
// Lateral Movement PID
int averagePosition = (leftPosition + rightPosition) / 2;
error = averagePosition - desiredValue;
derivative = error - prevError;
double lateralMotorPower = error * kP + derivative * kD;
// Turning Movement PID
int turnDifference = leftPosition - rightPosition;
turnError = turnDifference - desiredTurnValue;
turnDerivative = turnError - turnPrevError;
double turnMotorPower = turnError * turnkP + turnDerivative * turnkD;
// Apply motor power
FrontLeft.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
BackLeft.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
FrontRight.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
BackRight.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
// Update previous errors for the next loop iteration
prevError = error;
turnPrevError = turnError;
return 1;
void pre_auton(void) {
vexcodeInit();
// Auton
void autonomous(void) {
// Step 1: Launch the catapult
vex::task testerPID(drivePID); // Comment if doesn't work
targetPosition_catapult = 500.0; // Desired angle
catapultPID(); // Run the catapult PID function
desiredValue = 5000;
desiredTurnValue = 500;
resetDriveSensors = true;
drivePID();
// FrontLeft.spin(forward, )
// Step 2: Drive and turn
// desiredValue = 200; // Move 200 units forward
// desiredTurnValue = 15; // Turn 15 units
// resetDriveSensors = true;
// enableDrivePID = true;
// drivePID(); // Run the drivetrain PID function
// Step 3: Activate pneumatics for the wings
// Wings.set(true);
// Step 4: Drive forward, pick up balls, then drive backward
// This step might involve more specific commands or additional PID/target value adjustments
// Ensure to end tasks or movements appropriately, potentially with additional steps or checks
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void usercontrol(void) {
while (1) {
bool wasButtonAPressed = false; // Variable to remember the button state in the previous iteration
// Drivetrain controls
int forwardBackward = Controller1.Axis3.position(); // Left joystick for forward/backward
int turning = Controller1.Axis1.position(); // Right joystick for turning
// Mixing for tank drive control
int leftMotorSpeed = forwardBackward + turning;
int rightMotorSpeed = forwardBackward - turning;
FrontLeft.spin(forward, leftMotorSpeed, percent);
BackLeft.spin(forward, leftMotorSpeed, percent);
FrontRight.spin(forward, rightMotorSpeed, percent);
BackRight.spin(forward, rightMotorSpeed, percent);
// Catapult control - Button X
if (Controller1.ButtonX.pressing()) {
// Rotate the catapult to 80 degrees at a certain speed.
// The motor will automatically stop once it reaches the target rotation.
Catapult.rotateTo(500, deg, 90, velocityUnits::pct); // 50% speed, for example
// Wait until the motor stops (reaches the target), you can also add a timeout to prevent an infinite loop
while(Catapult.isSpinning()) {
// You might want to do something while waiting or just do nothing
vex::task::sleep(20); // Sleep to prevent hogging the CPU
// Optional: pause here if you want a delay before the catapult returns
vex::task::sleep(500); // Pause for 0.5 seconds, for example
// Rotate back to the original position (0 degrees)
Catapult.rotateTo(0, deg, 50, velocityUnits::pct); // Assuming the original position is 0 degrees
// Again, wait until the motor stops
// Pneumatics for wings - Button A (Toggle)
static bool wingsExtended = false; // holds current state of wings
bool isButtonAPressed = Controller1.ButtonA.pressing(); // checks if button is currently pressed
if (isButtonAPressed && !wasButtonAPressed) { // if button is pressed now and was not pressed before
wingsExtended = !wingsExtended; // toggle state
Wings.set(wingsExtended); // set wings to current state
wasButtonAPressed = isButtonAPressed; // remember the current state for the next iteration
// Intake control - Left Trigger
if (Controller1.ButtonL2.pressing()) {
// Spin the intake motor. You need to replace "Intake" with your actual motor's name
Intake.spin(forward); // You might want to set a speed here
} else {
Intake.stop();
// Scooper control - Right Trigger (Pneumatic, hold-controlled)
if (Controller1.ButtonR2.pressing()) {
// Assuming "Scooper" is your pneumatic device for the scooper
Scooper.set(true); // Engage the scooper
} else {
Scooper.set(false); // Disengage the scooper
// Sleep the task for a short amount of time to prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
So I want to know when you set the desired value and desired turn value in the auton, how does it work and how am I supposed to make it work? In the autonomous section, you can see that I commented out the Catapult PID part because it didn’t work when I ran it from my controller and timed run that has the auton. It didn’t even move.
Please teach me, also I know it’s not very advisable and respected to get spoon-fed help like this but I am seriously stuck. Thank you.
