would it be possible to run a lady brown mech off of a 5.5w motor that is geared for torque
Yes but the motor might burn up after a couple uses, so maybe use 2(one on each side)
the issue im running into is that i have a 6 motor drivetrain, and i use one motor for my second stage which runs at 550 so im in a pickle with the last motor cause i was thinkin of splitting the 5.5w one for first stage one for lady brown
Ok I recommend 5.5 watt first and second stage and 11 watt lb
It may be unconventional but it solves the problem of wanting more power in the intake but still supplying enough power to the lady brown when needed.
I plan on doing a design with a 11 watt second stage, 11 watt first stage (2 5.5 watts) and have a pto kinda thing that engages the first stage motors to the lady brown mechanism.
