Specs:
6 Motor High Torque Lift
4 Motor Turbo Drive
Potential High Hang (Just need Pole to measure)
Pneumatic Tension Release
Flip out anti-tip
Double Acting Piston Claw
I forgot to add the tension release video =(
Specs:
4 Motor Turbo Drive
Flip out anti-tip
I’m not sure if I’m missing something but what’s the tension release for?
Nice looking robot, by the way.
“Turning off” thee rubber bands used to help the lift. This allows for this bot to high hang with its lift.
How did u make so good robot??
Like I can only flip stool in regular speed. How to slow
Mars sounds good. I can contact a few guys and get the blueprints to a vasimr powered DUC. (direct universal carrier) It was designed for a 90-120 day trip. Should have enough space for a few teams to do filming.
Or just add more rubber bands.
How many actuations do you get from your claw? Is it powered in both directions or just for close?
@wesleywong what gear ratio are u using on the lift
We get like 40, enough to last a match
1:5
How do you get 40 uses?
cause you do?
¯_(ツ)/¯ ¯(ツ)/¯ ʅ(ツ)ʃ
乁(ツ)ㄏ 乁(ツ)∫ ƪ(ツ)∫
¯_₍ッ₎/¯ 乁₍ッ₎ㄏ ʅ₍ッ₎ʃ
¯_(シ)/¯ ¯_(ツ゚)/¯ 乁(ツ゚)ㄏ
¯_㋡_/¯ ┐_㋡_┌ ┐_(ツ)┌━☆゚.*・。゚
¯_(⌣̯̀ ⌣́)/¯ ¯_(ಠ_ಠ)/¯ ¯_(ತ_ʖತ)/¯
¯_(ಸ ‿ ಸ)/¯ ¯_(ಸ◞౪◟ಸ)/¯ ¯_( ´∀`)/¯
¯_(Φ ᆺ Φ)/¯ ¯_(´◉◞౪◟◉)/¯ ¯_(´・ω・`)/¯
¯_(˶′◡‵˶)/¯ ¯_(ಥ‿ಥ)/¯ ¯_(;へ:)/¯
¯_(ᗒᗩᗕ)/¯ ¯_( ´・ω・)/¯ ¯_(๑❛ᴗ❛๑)/¯
¯_(´°̥̥̥̥̥̥̥̥ω°̥̥̥̥̥̥̥̥`)/¯ ʅ(´◔౪◔)ʃ ┐( ̄ー ̄)┌
★。・:*¯_(ツ)/¯*:・゚★
Yeah, after fixing all of our leaks we got to 52 actuations on our claw.
we’re suffering under a similar problem to the disconnection you had at the Tracy tournament VEX Starstruck: Google Tournament [2017] - YouTube
did you ever fix this problem?
yes, we found a fix to the problem, we just needed to lighten our robot and to move 2 motors from the power expander back into the cortex.
wait… so it was because your motors were drawing too much power? Correct me if I’m wrong, but wouldn’t that cause a circuit to trip and that circuit to not work; not crash the cortex and restart it again… then again we may have different problems… does your cortex have two orange LEDs before it reconnects?
