So I have a 6 bar lift with 4 motors and looking if someone can help me code. So I’m usually the builder for my team and I don’t really know coding. Anyone know how to do this. I tried if statements and else but it doesn’t work. Thanks
What have you already tried? If statements are what you use to create it.
What you do is have a condition checking for if a button is pushed, and have a response based on that. The conditions would be inside a while loop.
if (vexRT[Btn6U] == 1)
motor[fourLeft] = 127;
motor[fourRight] = 127;
motor[sixLeft] = 127;
motor[sixRight] = 127;
else if (vexRT[Btn6D] == 1)
motor[fourLeft] = -127;
motor[fourRight] = -127;
motor[sixLeft] = -127;
motor[sixRight] = -127;
else
motor[fourLeft] = 0;
motor[fourRight] = 0;
motor[sixLeft] = 0;
motor[sixRight] = 0;
So wondering what ports do you think it should go in. And a while loop is this right
#pragma config(Motor, port1, fourLeft, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, fourRight, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port3, sixLeft, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, sixRight, tmotorVex393_MC29, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
while(true)
else
motor[sixLeft] = 0;
You forgot the set braces for the while loop
So where to place it new to coding learning still
