Hello,
New EasyC coach here. My team is doing a six motor bot (3 on the left, 3 on the right) but, EasyC doesn’t support that configuration in Arcade style. My guess is that we should just use two Arcade blocks and configure them for L1,L2,R1,R2 and L2,L3,R2,R3. Will that work?
Alternatives?
-d
Hello???
Anyone out there? Was I unclear? I could really use some help.
I’m not sure what you mean by L1,L2 etc…
You are right though, just use two arcade blocks. Map the joystick channels the same and list four of your motors in one and two in the other. I would recommend you don’t mix the ports eg 1 and 10 with 2 - 9 in your drivetrain.
Good Luck
L1 meant Left 1
R1 meant Right 1 etc…
cool. I’ll get on it this evening.
Thanks…
-d
