my drivetrain is set to reverse inputs, so forward is backwards, and left is right. I cant seem to find a way to change it so that forward is forward ect. can i get any help on this? thank you!
Code:
#include "vex.h"
using namespace vex;
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain Brain;
// VEXcode device constructors
controller Controller1 = controller(primary);
motor leftMotorA = motor(PORT11, ratio6_1, false);
motor leftMotorB = motor(PORT12, ratio6_1, false);
motor leftMotorC = motor(PORT1, ratio6_1, false);
motor_group LeftDriveSmart = motor_group(leftMotorA, leftMotorB, leftMotorC);
motor rightMotorA = motor(PORT20, ratio6_1, true);
motor rightMotorB = motor(PORT19, ratio6_1, true);
motor rightMotorC = motor(PORT10, ratio6_1, true);
motor_group RightDriveSmart = motor_group(rightMotorA, rightMotorB, rightMotorC);
inertial DrivetrainInertial = inertial(PORT18);
smartdrive Drivetrain = smartdrive(LeftDriveSmart, RightDriveSmart, DrivetrainInertial, 299.24, 320, 40, mm, 0.6);
// VEXcode generated functions
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool DrivetrainLNeedsToBeStopped_Controller1 = true;
bool DrivetrainRNeedsToBeStopped_Controller1 = true;
// define a task that will handle monitoring inputs from Controller1
int rc_auto_loop_function_Controller1() {
// process the controller input every 20 milliseconds
// update the motors based on the input values
while(true) {
if(RemoteControlCodeEnabled) {
// calculate the drivetrain motor velocities from the controller joystick axies
// left = Axis3 + Axis1
// right = Axis3 - Axis1
int drivetrainLeftSideSpeed = Controller1.Axis3.position() + Controller1.Axis1.position();
int drivetrainRightSideSpeed = Controller1.Axis3.position() - Controller1.Axis1.position();
// check if the value is inside of the deadband range
if (drivetrainLeftSideSpeed < 5 && drivetrainLeftSideSpeed > -5) {
// check if the left motor has already been stopped
if (DrivetrainLNeedsToBeStopped_Controller1) {
// stop the left drive motor
LeftDriveSmart.stop();
// tell the code that the left motor has been stopped
DrivetrainLNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the left motor nexttime the input is in the deadband range
if (drivetrainRightSideSpeed < 5 && drivetrainRightSideSpeed > -5) {
// check if the right motor has already been stopped
if (DrivetrainRNeedsToBeStopped_Controller1) {
// stop the right drive motor
RightDriveSmart.stop();
// tell the code that the right motor has been stopped
DrivetrainRNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the right motor next time the input is in the deadband range
// only tell the left drive motor to spin if the values are not in the deadband range
LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, percent);
LeftDriveSmart.spin(forward);
// only tell the right drive motor to spin if the values are not in the deadband range
RightDriveSmart.setVelocity(drivetrainRightSideSpeed, percent);
RightDriveSmart.spin(forward);
// wait before repeating the process
wait(20, msec);
return 0;
* Used to initialize code/tasks/devices added using tools in VEXcode Pro.
* This should be called at the start of your int main function.
void vexcodeInit( void ) {
Brain.Screen.print("Device initialization...");
Brain.Screen.setCursor(2, 1);
// calibrate the drivetrain Inertial
wait(200, msec);
DrivetrainInertial.calibrate();
Brain.Screen.print("Calibrating Inertial for Drivetrain");
// wait for the Inertial calibration process to finish
while (DrivetrainInertial.isCalibrating()) {
wait(25, msec);
// reset the screen now that the calibration is complete
Brain.Screen.clearScreen();
Brain.Screen.setCursor(1,1);
task rc_auto_loop_task_Controller1(rc_auto_loop_function_Controller1);
wait(50, msec);
edit: code tags were added by moderators, please remember to use them.
