6 motor drivetrain code
I was wondering if it was possible to make a 6 motor drive train code where 1 joystick controls the forward and backwards movement while another controls the turning.
It is, use the forum search and you will find several discussions on that topic.
If you are having trouble searching on the forums.
The control layout you are talking about is arcade but you want it split between the 2 joysticks so more accurately split arcade.
Hope this helps. :slight_smile:
