I just transitioned to using vexcode pro when we upgraded to a 6 motor drivetrain. I used this video to program it here
I transferred the code from nonexpert mode over to expert mode and added the 2 extra motors. When I go to change velocity, the robot drives forward and turns fine but when going backwards, it constantly goes back and forth(I am using arcade). When velocity is just default, the robot drives fine, except for when going backwards it just goes slow, WHAT DO I DO??
Robot configure code:
#include "vex.h"
using namespace vex;
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain Brain;
// VEXcode device constructors
controller Controller1 = controller(primary);
motor leftMotorA = motor(PORT2, ratio18_1, false);
motor leftMotorB = motor(PORT1, ratio18_1, false);
motor leftMotorC = motor(PORT9, ratio18_1, false);
motor_group LeftDriveSmart = motor_group(leftMotorA, leftMotorB, leftMotorC);
motor rightMotorA = motor(PORT11, ratio18_1, true);
motor rightMotorB = motor(PORT16, ratio18_1, true);
motor rightMotorC = motor(PORT15, ratio18_1, true);
motor_group RightDriveSmart = motor_group(rightMotorA, rightMotorB, rightMotorC);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 406, 306, mm, 1);
motor MotorGroup5MotorA = motor(PORT19, ratio18_1, true);
motor MotorGroup5MotorB = motor(PORT20, ratio18_1, false);
motor_group MotorGroup5 = motor_group(MotorGroup5MotorA, MotorGroup5MotorB);
// VEXcode generated functions
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool Controller1RightShoulderControlMotorsStopped = true;
bool DrivetrainLNeedsToBeStopped_Controller1 = true;
bool DrivetrainRNeedsToBeStopped_Controller1 = true;
// define a task that will handle monitoring inputs from Controller1
int rc_auto_loop_function_Controller1() {
// process the controller input every 20 milliseconds
// update the motors based on the input values
while(true) {
if(RemoteControlCodeEnabled) {
// calculate the drivetrain motor velocities from the controller joystick axies
// left = Axis3 + Axis1
// right = Axis3 - Axis1
int drivetrainLeftSideSpeed = Controller1.Axis3.position() + Controller1.Axis1.position();
int drivetrainRightSideSpeed = Controller1.Axis3.position() - Controller1.Axis1.position();
// check if the value is inside of the deadband range
if (drivetrainLeftSideSpeed < 5 && drivetrainLeftSideSpeed > -5) {
// check if the left motor has already been stopped
if (DrivetrainLNeedsToBeStopped_Controller1) {
// stop the left drive motor
LeftDriveSmart.stop();
// tell the code that the left motor has been stopped
DrivetrainLNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the left motor nexttime the input is in the deadband range
if (drivetrainRightSideSpeed < 5 && drivetrainRightSideSpeed > -5) {
// check if the right motor has already been stopped
if (DrivetrainRNeedsToBeStopped_Controller1) {
// stop the right drive motor
RightDriveSmart.stop();
// tell the code that the right motor has been stopped
DrivetrainRNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the right motor next time the input is in the deadband range
// only tell the left drive motor to spin if the values are not in the deadband range
LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, percent);
LeftDriveSmart.spin(forward);
// only tell the right drive motor to spin if the values are not in the deadband range
RightDriveSmart.setVelocity(drivetrainRightSideSpeed, percent);
RightDriveSmart.spin(forward);
// check the ButtonR1/ButtonR2 status to control MotorGroup5
if (Controller1.ButtonR1.pressing()) {
MotorGroup5.spin(forward);
Controller1RightShoulderControlMotorsStopped = false;
} else if (Controller1.ButtonR2.pressing()) {
MotorGroup5.spin(reverse);
} else if (!Controller1RightShoulderControlMotorsStopped) {
MotorGroup5.stop();
// set the toggle so that we don't constantly tell the motor to stop when the buttons are released
// wait before repeating the process
wait(20, msec);
return 0;
* Used to initialize code/tasks/devices added using tools in VEXcode Pro.
* This should be called at the start of your int main function.
void vexcodeInit( void ) {
task rc_auto_loop_task_Controller1(rc_auto_loop_function_Controller1);
