6 motor drivetrain Python coding
My team is using a 6 wheel, 6 motor drivetrain this year and we were having a bit of trouble programming our autonomous. We are using python in vexcode v5. I have found many posts about how to code a 6-motor drivetrain such as How do you program a 6 motor drivetrain but none of these happen to be in Python. Is there anyway that I could combine the 6 motors into one drivetrain in the way you can with 2 and 4 motor drives. If anyone has a solution to our problem, please share. Thanks!
Python code would be very similar to C++ code. Create the motors and motor groups, then the drivetrain. for example
# left motors
m1=Motor(Ports.PORT1)
m2=Motor(Ports.PORT2)
m3=Motor(Ports.PORT3)
mgl=MotorGroup(m1,m2,m3)
# right motors
m4=Motor(Ports.PORT8, True)
m5=Motor(Ports.PORT9, True)
m6=Motor(Ports.PORT10, True)
mgr=MotorGroup(m4,m5,m6)
# IMU
g1=Inertial(Ports.PORT11)
# create drivetrain
sd=SmartDrive(mgl, mgr, g1)
sd.drive_for(FORWARD, 12, INCHES)
Thanks this helped out a lot
