We are adding two wheels between our current 4 wheels. We are going to link them to the back wheels using a chain. Our front wheels are 4" traction, and our back wheels are 4" Omni-wheels. We are not sure whether to use the Omni-wheels, or traction wheels in the middle, could we please have some suggestions?
(Crappy MS paint drawing, not to scale).
Depends on what purpose you want the third wheels to have. I would suggest traction wheels, but note that VEX traction wheels are actually smaller than the VEX Omni wheels of the same listed size.
We want the wheels to help us get up the ramp, and to keeps rings out from there. There are rings guards, but if we pop a wheelie, they get caught there and we can’t move. I am also concerned about turning.
Then center traction wheels will help with your turning issues. As long as they co-linear with each other and your robot’s center of rotation (COR), your robot will always turn about the COR (as long as your robot maintains full 6 wheel contact with the ground for the duration of the turn).
Popping a wheelie has little to do with the number of wheels on your robot (4 or 6), and more to do with your robot’s center of mass. I suggest that you spend some time figuring out where it is currently on your robot, and how to move it to a more optimal position.
The issue with popping a wheelie is that when we are carrying a mobile goal, a ring will get stuck where we are about to put this wheel, so we are hoping it helps.
Since when was popping a wheelie a bad thing
If we do, then we can’t do it again because we have rings under us.
I would use traction but if you are having turning issues then use omni.
That is what we were gonna do. We figured it out. Thanks!
