@Collin Stiers, @technyk32, @Team3211H, @LEER, @frogs2345 you guys are coming up with so many good ratchet designs that I feel like I simply have to use one, regardless if the robot needs one or not!
Keep up the good work!
Actually, I am seriously considering using one. Could you elaborate on the maximum torques and/or shock loads the ratchet can withstand and any reliability lessons that you have learned with you designs?
I thought I should integrate one because Iām tired of the slow spindowns and motors clicking when TBH triggers quickly.
Iām kind of late to this thread, but I got one to work. It uses a helical gear as a ratchet gear, using the normal pawls on the ratchet. The pawls are sprung with zip ties on standoffs.
Could you post a picture?
I was just looking for a 60t gear based ratchet that could carry about 30 in-lbs of torque.
On a different note, does anyone have any ratchets for a 4" wheel that does not use the VEX ratchet? Iāve experimented with the one Cameron showed in the ri3d documentary, but it didnāt turn out too well.
heh
62th ratchet
we have a ratchet on our fw confirmed
This one canāt back off.
Iāve taken 5inch wheels on an axle and tried to back-drive it and hurt my hands trying to. Its just a little thicker than some other ratchets however. I had to re-space the gearboxes on my flywheel because it didnāt fit, while some others may have been able to. If you place the rubber links on the bottom of the pillow bearing, it is stiff, while if you place them on top of the pillow bearing, itās much looser (like what you would want on a flywheel).
Thatās kind of terrifying. I also kind of love it
