6671X is proud to present our 2018 Worlds Reveal!
We’re in the Technology Division.
Good luck to all teams competing!
Can’t wait to see it in person in the Technology Division! Good luck!
If you are using pneumatics for the intake 4-bar and also, it seems, the intake, how do you possibly have enough air for a full match? (About 20 cones stacked, and 5-10 moved to the stationary goal.) I got about 30 single-acting actuations last season with my two-piston claw, when pumped to 100 PSI. And yes, I did take care of all leaks.
We use about a third of a piston stroke each actuation of the 4 bar. The intake is passive going down on the cone and active releasing which saves a lot of air. We also use pressure regulators to conserve as much air as possible. We can do about 42 cones before it becomes inconsistent.
Okay. I had heard bad things about pressure regulators, but if they do help, then I can see how that would work. Best of luck!
Nice robot Aeden would be proud
TOoooooo stronnnnnngggggggggg
much op. Nice robot my doods. Ud better pick if ur cap 16 Haley
The Auton is really good
That speed of the Dr4b is absolutely insane. Good luck at Worlds!
