Sorry, mine’s a bit later because I’m on vacation and a mobile hotspot isn’t the most reliable thing in the world.
This is 675B’s robot this year. I apologize for the slightly unprofessional pictures - we didn’t have a high-end camera to use for them.
https://vexforum.com/gallery/files/4/1/6/3/0/8/dscn1253.jpg
https://vexforum.com/gallery/files/4/1/6/3/0/8/dscn1247.jpg
https://vexforum.com/gallery/files/4/1/6/3/0/8/dscn1257.jpg
And these are some pictures of a slightly older iteration of our robot. Since then, our arm has been strengthened and the ultrasonic sensors removed, along with the back support. It works much better now. However, the maneuvers are the same.
https://vexforum.com/gallery/files/4/1/6/3/0/8/20130131_161547_6.jpg
https://vexforum.com/gallery/files/4/1/6/3/0/8/20130131_161657_16.jpg
This robot features:
4 x 393 High-Speed motors 1:1 on the drive
–Chained together to help with stalling problems
–Chained to encoder with smaller sprocket for more precision
4 x 393 High-Strength motors 3:25 (torque) on the arm
–Large gear surface area for minimal loss of contact
–Gears screwed together for minimal axle shearing
–Unique gear ratio provides a more ideal speed-torque ratio than similar designs (slightly but noticeably faster arm)
2 x 393 high-Strength motors 1:5 (torque) on the scoop
–Reinforced (mechanically) solid piece of 1/16" polycarbonate, 17.5" wide, 9.5" long for maximum strength and surface area
Additional Features:
–Pneumatic support on back to aid in descoring as well as preventing the robot from flipping (can be disengaged and reengaged in case of actual flipping)
–2 x real-time Potentiometers used in conjunction with PID to give set angles at any arm height as well as maintaining the same angle as the arm raises/lowers
–Lots of nifty programming features that aren’t visible at all
–Potentiometer autonomous selector
–Handles!!!
Performance
–Average of 45 Autonomous points
–Average of 190 Robot Skills points (we’ve not had much practice :P)
–A pretty awesome Programming skills run, though it’s definitely not the highest scoring
This robot is capable of:
–Driving under the trough
–Quick and massive trough descoring under the right circumstances
–Trough scoring in the matter of a couple seconds
–Picking up 12+ sacks in a single load (we prefer not to strain the robot though…)
–High goal scoring
–High goal descoring
–Scoring backwards into the trough
–Something special we’ll share after World
This robot has won:
–1 Excellence Award
–2 Tournament Champions
–Competed well into the elimination rounds in 2 other qualifiers
