Cool bot, but I think your indexer and flywheel or “drums” as I think you called them could stand to be faster. It looks like your shots struggle to go far enough and the balls have to roll on the rim.
Why is your front row of indexers angled like that? My guess is that the point is to put the top roller as close to the goal as possible? It looks pretty jank too, and it is just confusing me all around
if your rollers happen to line up in a way that an angled tower will connect them all, there’s no good reason not to have a tilted tower like that. if you secure it right it won’t be jank.
2 people have released crooked tower reveals. At least it’s not a canti x-drive. Also can you show me a close up of the joint so I can see how you keep it at that angle? Depending on how it’s mounted it could be fine-ish-kinda-not-really.
I second this. My team has had great success with making our top roller spin stupidly fast to literally shoot balls in. Our roller spins at 3600 RPM and we never have issues getting balls in (A backboard attached to your robot really helps here)
Our indexers are attached like that for simplicity to mount them onto the front drum system. And yes, the front section is to get as close to the goal as possible. Our securing system is quite tight and does not move. It looks a tad weird, I’ll give you that, but it works pretty reliably.
And we will try playing around with the speeds. ok
