do guys think a 100% passive hanging method could be possible, one such as a 90 degree hang that was common last year, with the caveat that instead of another robot lifting you up, it would be alot of runner bands, and a passive claw, like this -
with the difference being that this one can fold back further into the robot, to be released by either pneumatics, or a lever. or three claws, for more grip
Yes; this could easily(ish) happen. However, as seen in NBN, motors are usually a better idea. I tink a double 4 bar like RI3D would honestly work better and be lighter. You could even have a release mechanism to add more elastics when the bot actually starts lifting. Yes, a viable solution, but in my opinion, there are better.
Ok, we already have an inovative lift, so if we can get the lift working $$$. Of course, the passive lift would probably lift faster, because of the rubber bands. Yeah we accedentally hurt myself using a piston shooter last year, still have a nasty scar on my wrist from that
A hook for sure. You could even do it like 8088X but add a few more elastics to pull a rotating arm up at the beginning of the match. (released by something like rubber bands on the wheels) Then have a little latch on the underside of the hook that releases one set of latex. The bot shoots up, and a passive lock holds it at the top.
