4 motor drive
1 motor lift
1 motor puncher
1 motor intake
1 motor puncher angler/parking brake
Nice robot! The NbN-esque skills run at the beginning almost made me choke on my tea…
If you haven’t already, make sure your license plates are compliant with the new rule <R20-e-i>, added in the recent game manual update:
If the plates are attached to opposite-color plates, the incorrect color must be covered, taped over, or otherwise obscured to ensure that the correct alliance color is abundantly clear to Head Referees during a Match.
Assuming you leave the red plates permanently attached and snap the blue plates over them when needed, some neutral-colored tape covering the back of the red plates is all you need to comply with this new rule.
Thanks! I wish we had time to pull the nets out of the basement to make it a little more accurate
We were just planning on taking off the license plates and attaching the other color since there is generally plenty of time in between matches at worlds.
I absolutely love that brake that you included!
