What it should do is left joystick controls left drive, right joystick controls right drive. What it does do is run both motors for 4 seconds and stops.
I’ve written other programs (run motor for 1 second, stop) and they work fine. I’ve updated CPU and Cortex firmwares on the cortex, updated joystick firmware on the controller, used multiple joysticks, cortexes, and programming cables.
I’ve checked that I don’t have any other programs in background tabs.
I’ve set it to VEX Cortex 2.0 and to Natural Language PLTW.
I’m out of ideas as to why a historically simple, rock solid program is acting this way.
I’ve seen this before where the download is something old. Dig in the cortex code directory for the .hex file and delete it. That will force the compile to happen.
The only .hex file I could find there, VEX_Cortex_1056.hex, gives me the error message “FILE ACCESS DENIED You need permission from SYSTEM to make changes to this file”
