About the Inertial sensor
B5E3C874-28B4-4ecf-8CF0-E3922C1B10D8
Can you tell me?
Why do their values continue to accumulate after the angle of rotation?
thanks!
You need to refresh your brain screen on every new loop stage
clear all rows
on the start of forever loop
Clear All Rows
I would also recommend a calibration block at the beginning of your project. If the values are changing when the Inertial sensor is stationary, then that usually indicates an improper calibration.
Remember to keep the sensor still while calibrating - takes about 2 seconds to complete.
Screen Shot 2021-01-26 at 8.26.46 AM
I also encountered this problem. Before the project started, the calibration block was used. After calibration, the value of the inertial sensor stabilizes at about 0.6, but after two seconds, the value of the inertial sensor will slowly increase from 0.6 to 1.0 to 2.0。Keep increasing
Well, thank you very much, I will try again later.
:思维:thank you very muck.I will try again later
