About the transmission frequency of digital signals
I want to know the frequency of the V5 triport when it‘s set the mode digitalin or digitalout.
are you talking about the 3-Wire Expansion ports on the V5? if so I would check out the cortex documents. (8) 12-bit Analog Inputs * Analog In: 12-bit resolution. 10 μSec access time.
This page (scroll down to the table labeled “3 wire specifications”) lists the digital message rate as “on change up to 1 kHz”.
In practice it’s around 100Hz
