Hi,
I’m trying to program Accelerometer 1.0 with VEXcode V5 Text, according to the product description, it has two sensitivity ranges: +2g to -2g(with out jumper) and +6g to -6g(with jumper). So I installed one accelerometer to my V5 robot horizontally, connect Z axis to V5 brain, and leave the robot on table don’t move. then printed the sensor value to brain screen, result as below screenshot:
According to the production description https://www.vexrobotics.com/276-2332.html#Description the sensor will detect a constant 1.0G while at rest, so the result here seems incorrect. then I made another test, which choose Accel6G in VEXcode, but removed the jumper(so the accelerometer range should be +2g to -2g), then printed the value: 1.00
So the device type here in VEXcode V5 Text was wrong or my first test was wrong? Anyone can help verify this issue?
Thanks in advance.
