Active Intake or High speed Lift?
So we’re in a situation where our motor distribution is such that we can choose between a 2 motor lift with an active intake or a 4 motor lift with a passive intake. right now we’re favoring the active intake, because our driver is much more experienced with them and we’re not sure he can learn to control a high speed 1:5 lift before Saturday. Do you think we’re making the right choice or should we go with the 4 mtr lift option?
Have you made a passive intake that works yet?
No. Not even close.
Because we don’t have plexiglas because our robotics instructor had his appendix removed.
We should be able to get a 4 motor lift and active intake later when we have the time to convert to a 1 motor mogo intake, but the others are pretty certain we won’t be able to make that jump in time for Saturday.
Then I would suggest that you go with the active intake as your driver has practice with it. Get some driving practice in and make some good autonomous routines. Come up with a match strategy and test it with the field setup and under match time constraints.
Ok, thanks.
What is your mobile goal intake ratio?
1:5.
I believe our arms are 7 inches long, somewhere in that ballpark.
I have seen a one motor torque 1:5 mobile goal intake work.
Just depends on what angle your arm attached to the gear is at when you are picking up the mobile goal.
#PassivenotWorth
About the same angle yours was at in your reveal with 1970k, about 45 degrees or so.
I think 1:5 with one torque should be fine if rubber-banded to help lift. And I agree 2 motor lift active intake for saturday.
