AI Vision Sensor not showing as a network
I’ve been trying to connect my AI Vision Sensor to my laptop and my students Chromebook to display the camera remotely. You are supposed to have the AI Vision sensor wifi turned on under the Brain settings, then connect to the Wifi network and finally input an IP address to connect the camera to an external monitor. You used to be able to do this with the older vision sensor.
The new V5 aivision sensor does not support wifi. The wifi setting on the V5 brain is for the legacy vision sensor.
