Angle Beams? Why are they called 30, 45 & 60 degrees?
I don’t understand why the three angle beams are called 30 Degree Angle Beam, 45 Degree Angle Beam & 60 Degree Angle Beam? In my limited math knowledge, they should be numbers over 90 degrees. Why are they labeled as what I would think would be their complementary angle? I’m not sure how to explain this to my students.
The value is the amount of deflection from a straight beam.
If you were to add to your picture, on the far left end, a 1 x 5 beam and label it as “0 degree” then the others will all make sense.
Of course; if you name the straight beam a “180 degree angle beam” then the others names do not make sense.
Paul
Lay them down in the mirrored position of what you have now, then it may make more sense.
