Angled drive train connections
Hello for high stakes I am looking to make angled drive train connections to build a funnel.
How is this done in this photo, it looks like the standoffs are attached to shaft collars, how might this be done?
The threading of the shaft collar is 8-32, same threads as the standoff. You can buy “standoff connectors” or you can just cut a 1/2" long threaded portion of a screw with a hacksaw and file the ends neatly, to connect the standoff to the shaft collar.
? It’s the same size as a regular screw?
Thank you I will try this,
I must have thought this due to the different star drives needed.
Just a little recommendation.
Funnels are used so that if a ring hits the side of your drive, they go into the center of your robot for pickup. Currently, your funnel maks rings go outwards instead of inwards.
Oh sorry, this is not my bot I’m just using the same construction methods to build one/reverse it
