Answer to "Clutches"
You can find replacement ones here, http://www.vexrobotics.com/vex-robotics-cables-accessories-parts.shtml a little down the page.
There are no steel ones available as of yet…unfortunately.
I doubt they will release the “steel inserted” clutches due to the fact that they are used to be a mechanical “break” to stop the motors from stripping on the inside.
Personally, I don’t like to use clutches in competitions due to the likelihood of them stripping out, but if the VEX system is used in a classroom or around people who have never played with VEX before, it’s a good idea to use them.
That was my first thought when I read this post, but I think he may be asking for clutches with steel axle hole inserts. He may be striping out the axle holes, not the friction mechanism.
  • Dean
my thoughts exactly, when im running out of metal (not enough to have a collar in between two pieces of metal to stop the axle falling out of the clutch&motor) i attach my axle in a slightly different way (Motor->Clutch->Collar->Axle->Metal, use longer screws and washers) which has stripped the surroundings of about three clutches now
Like this?
[FONT=Courier New]|` _____[/FONT] [FONT=Courier New]m`|\|```` |||[/FONT] [FONT=Courier New]o`|||[/FONT]clutch[FONT=Courier New]|=| o |======[/FONT] [FONT=Courier New]t`|/|_____| ||[/FONT] [FONT=Courier New]o|````````````` ||[/FONT] [FONT=Courier New]r``````````````` ||[/FONT]
