Answer to "Vex Robot Problem"
If the battery LED is flickering green and red then chances are your battery is low and should be replaced/charged. A battery LED at Red means it is low.
You should also update your master code which can be found here,
http://www.vexlabs.com/vex-robotics-downloads.shtml
