Not sure if I worded that properly . . .
I have designed a robotic arm. I have a gear system that give me a lot of torque for the elbow joint. However, when the forearm is extended, and no signal is sent to the motor, the forearm just slowly swings down perpendicular to the floor. I can hear it turning the interal gears in the motor.
I engage the motor, and it moves the elbow just as it should, in both directions. But when I take my fingers off the buttons, the arm falls down to the perpendiular positon.
This is with no add’l weight in the gripper. It is only holding the weight of the hand.
is this normal behavior for the 393? It does not occur when I use the 269 motors.
Thanks!
Todd
