Where do i find instuctions to do this?
How do i make my my squarebot 4 wheel drive?
The squarebot already is 4WD. The motors in the center drive both wheens through the geartrain.
Iâm not sure what youâre asking.
Mr. V-Neun
What i am asking is how to build a version of squarebot that has a motor attached to each wheel (4WD). thank you for answering my post in the first place.
CADONE
We do not have instructions provided for this.
Simply mount the 4-motors to your chassis (similarly to how they are mounted in the squarebot) in the positions where you want your wheels.
You should have 2 chassis rails in usage. The outer-rail would have a bearing mounted to it at each wheel location. The inner-rail would have a motor mounted to it at each wheel location.
For each wheel:
[LIST]
*]Run an axle from the motor, though the bearing so it is hanging outside the chassis.
*]Install a shaft collar in between the inner and outer chassis rails to keep the shaft from sliding out.
*]Install the wheel on the part of the shaft sticking out from the chassis. (You may need to place a spacer in between the wheel and the chassis to keep it from scraping on the chassis rail.)
*]Place a shaft collar on the shaft to hold the wheel on.[/LIST]You can see an example of what Iâm describing, in the attached image.
(Repeat that 4 times.)
Hope this helps.
Regards,
John
Details on activating the 4-Motor drive can be seen on page 7-12 of the Vex Inventorâs Guide.
For 4WD with 2-stick âTank Styleâ Drive:
[LIST]
*]Plug the FRONT-RIGHT motor into Motor Port # 2
*]Plug the FRONT-LEFT motor into Motor Port # 3
*]Plug the BACK-RIGHT motor into Motor Port # 7
*]Plug the BACK-LEFT motor into Motor Port # 8[/LIST][LIST]
*]Place a Jumper into I/O Jumper Port # 15 to activate 4WD Mode with Tank Steering[/LIST]
**For 4WD with 1-Stick âJoystick Styleâ Drive:
[LIST]
*] Plug the FRONT-RIGHT motor into Motor Port # 2
*] Plug the FRONT-LEFT motor into Motor Port # 1
*] Plug the BACK-RIGHT motor into Motor Port # 7
*] Plug the BACK-LEFT motor into Motor Port # 8[/LIST] [LIST]
] Place a Jumper into I/O Jumper Port # 16 to activate 4WD Mode with Joystick Steering
] Place a Jumper into I/O Jumper Port # 14 to activate Joystick Steering[/LIST]
Thanks a bunch, john, those last few posts really helped. i did not think to put a bearing on it at all, so i probably would have torn up my motors.
Thanks Again,
CADONE
